New to the square body scene
iservin619
san diego ca
Ivan
GMC sierra
350 small block
Welcome! My Q-Jet was unsalvageable, so I talked to the good folks at Summit, who got me dialed in to the right Edelbrock carb for my '86 C2500 Crew. The nice thing about the Edelbrock carb is that it comes with a booklet that explains carb tuning, and does it so well that I got the thing through CA's notorious smog check. Then I explained tuning to my nephew, and he was able to get his Weber through smog as well. Have fun!
Damn I ordered a carb from national carburetors so we’ll see how that goes definitely liked to hear you passed the infamous California smog that thing is brutal. Thanks for the info I’ll definitely get an edelbrock down the line.
iservin619
san diego ca
Ivan
GMC sierra
350 small block
Welcome from Montana. I, too, am a Q-Jet man. I've rebuilt several & have had great luck with them. Make sure you check the play on the throttle shaft, because if it's wore out, it'll suck in air and to my knowledge, you'll have to ****-can it. The carb numbers on the side tell the story, including the build date. You'll also need them to purchase the correct kit. CLEAN IT WELL!!! I've used laquer thinner and an old toothbrush in the past, but you can degrunge the bulk of it with a spray can of carb cleaner
I bought a kit from mountain man told him the carb # and all that. I appreciate the tips on cleaning it. I still need to purchase the book everyone always talks about cause at the moment I have no clue how tune, clean or rebuild. Got a lot to learn but this community has been nothing but a help which I appreciate. Thank you
iservin619
san diego ca
Ivan
GMC sierra
350 small block
Welcome from a fellow San Diegan. Good looking truck.
I also forgot to add is there a special tuning tool I need for the new Q-jet I’m receiving this Friday. Like I mentioned in another reply I still need to buy the Q-jet book and go over it. Another question for you and anyone else that might have input. The 2 steel lines that attach to the carb (fuel and brake not sure) look to be crimped a little. Would I need to get that replaced or is it fine how it is? I’ll attach pictures in a couple minutes. Thanks
iservin619
san diego ca
Ivan
GMC sierra
350 small block
Welcome!
Great looking truck, thanks for the pic.
Now give us some shots from under the hood…
Sorry for the late reply wasn’t letting me attach photos for some reason.
75 Chevy SWB 4x4
NE Oregon
Doug
K10 4x4
Welcome from NE Oregon!
Looks like a really nice pickup you got from your dad.
Hard
