Lowering my 1982 GMC
MikeB
North Texas
Standard 15x8 Rally Wheel with 235/60/15 tires, no issues at all
Hmm, other threads on this forum say a stock 8" rally will hit the A-arm or tie rod end. Even McGaughy's told me I'd need a narrower wheel with less backspacing. Wonder what's different about your setup. ???
Ohio
Mark
5.3L
I had to grind a minimal amount off the tie rod end to clear the rim. I also had to use stick on weights instead of the old hammer on weights.
Ohio
Mark
5.3L
MikeB
Here is a pic of how close the steering link is to my rim. I had to grind a small amount to clear my wheel. For some reason the pic is upside down.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Geez...now that's close. I didnt have any issues like that when I had the oem rallys on my square. The clearance issues I had was the lower control arm rubbing the inner edge of the wheel just enough to rip the weights off.
JoshuOne
