Yellow Wire is Constant no?
Spool
Los Angeles
Thomas
Hey Guys.
1973 Chevy C20 with a mess of wires I'm trying to clean up.
I've replaced the stereo earlier this year but it would cut out once in awhile so I decided to check the connections and follow the ground, constant and ignition.
I found it connected to (extremely messy in about 5 connections) out to the hood, and then grounded after passing a 20Amp fuse.
What I would like to do is power it straight to a On/Off switch and leave the ignition out of it.
Battery to Supply.
Radio to ACC.
Earth to Ground.
But where would the yellow constant go coming off the stereo?
And does there need to be a fuse on the cable?
I've uploaded this youtube clip to show the mess and fuse.
https://youtu.be/RE-H65eWl1Y
Any help is appreciated. Thank you.
brewster21
Iowa
Jason
What head unit did you put in,
Then I'll just look up the manual and tell you what wires to run where
Sent from my LGUS991 using Tapatalk
Mousta5
