WTB "With Tach" fuel gauge
FRANKENTRUCK
By The Sea
Pierce
C10 Deluxe Stepside C10
350 with 350 Turbo transmission
I finally found a factory tach and am putting together a new gauge pod to replace my idiot lights. Does anyone have a good condition "with tach" type fuel gauge that goes in the bottom left of the gauge pod? I need the type that has lettering, NOT pictures.
FRANKENTRUCK
By The Sea
Pierce
I appreciate the link but I tend to stick with original parts whenever posssible.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Understandable. However, finding the originals will be quite tough.
FRANKENTRUCK
By The Sea
Pierce
That is very true! I intend to build an original gauge pod with the desired gauges and use them. If they are to my liking I will continue with them. If any go bad or they are not accurate enough I may consider building a modern day one with repro gauges (that would look GOOD). The tach arrived today and I installed it into the "target" gauge casing along with my 100 mph speedometer, a volt gauge, an oil pressure gauge, and a temp gauge. The one bottom left slot is reserved for the small "with tach" fuel gauge. The tach needle stays at 5 instead of zero. Is this normal? The tach is untested so it could be anything.
RetroC10Sport
Jay
pontiac aztek
Obullard74
