Wondering what I have?
Well it's a 87 suburban 2500 lifted I don't know how much just clears 35s but I want 38s because the 35s drag my front and rear diffs on the trail to where I like to fish I don't know what all has been done to it I bought it this way
Here is a picture of it like I said 35s i don't know what Alls been done
Now, where getting somewhere. That looks to be about a 4 inch. You should already have the drop steering arm I'd imagine. That's not a bad looking stance at all. But you're purpose for going to 38's is to get more ground clearance? That's a whole lotta money to spend on 38's just to gain 1 1/2 axle clearance and it's in reality, probably more like 1 1/4. The trail must be rutted up pretty bad huh? You realize a lift kit, body or suspension either one will NOT cure differential clearance. Noway to drive one side or the other of the ruts? You know your front diff pumpkin is on the passenger side, so maybe stay to the right of the rut and the front may clear. The rear axle can be shaved a bit if done right for a bit of clearance, and also if done right, even if it does drag, it won't tear anything up.
1911_colt
Washington
Michael
Suburban 2500
Ya I know it won't give me much more and ya the ruts are bad we high centered my father in laws 4runner on the ruts it has 33s and I have a free set o 38s from my dad and that is the biggest I wanna go with my kids being rather little and so my dog can still jump into the back
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
the lift looks more like 6'' to me
it is possable you have 4:10 gears i just moslty have seen 3/4 ton subs with 3:73
heavyleft
Fayetteville, NC
V10/K5
350ci
You realize a lift kit, body or suspension either one will cure differential clearance.
Ahem...hehe....since when does a lift of any kind give you more ground clearance from the bottom of your diffs housings when the lift is all above the axles? Tires are whats going to get him more diff clearance from the ground.
The 38s will require some fender trimming, more than likely, with that lift you have.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
I wondered about that...Ol' HR is getting absent minded?
DOH, FORGOT the NOT. That was my whole point in making the statement, that It won't. Need to edit that.
1911_colt
Washington
Michael
Suburban 2500
I also want that look too with how big the body of my suburban is I need a bigger tire to make it look the way I want
Looks like 6" to me also.
I don't think you will be able to get it much higher without spending a bunch of money. You can do things like adding "zero rates" to the springs and running longer shackles up front, but you will be at the point of needing custom driveshafts and more steering mods. Might as well just lift it again with the right parts to get the tire clearance you want and then sell your current lift parts that will be left over.
jerdanwey
