Wiring harness
Denvernic
Wichita KS
Denver
350TBI
I have an 87 K5 the wiring under the dash and under the hood are jacked. There a melted spot on the fuse box where the turn signal fuse goes and a previous owner installed an alarm system and remote start that i think they tried to do on there own and didnt have a clue what they were doing. So Im planning on rewiring the entire truck. My question is who has done this before and what harness did you use like a painless or one from LMC ect? How big of a pain was it?
You got a pull a part around you can go get a whole factory harness from?
Denvernic
Wichita KS
Denver
350TBI
yeah theres a few of them and ive called around but havent found anything
I'll have to keep this in mind my next trip to PAP, pull some factory harnesses to sell here.
robert8096
Goose Creek SC
Robert
Denvernic
Wichita KS
Denver
350TBI
robert8096
Goose Creek SC
Robert
Have not put the Painless in yet and just started on the the Speedway. The Painless will fit in the stock location and not require any mods.
The Speedway requires you to mod or fill the firewall opening. Watch all of those videos. The guy shows you how he modified the firewall to accommodate the Speedway. Also download the manual for wiring harness and read thru them.
Both kits are well marked and once you get the fusebox mounted it's just a matter of routing the wires and connecting the components.
Denvernic
Wichita KS
Denver
350TBI
Cool thanks alot for the help im goin to look into the speedway a lil more and go from there.
That speedway kit looks nice and affordable and that instruction PDF file is really nice. :)
chevyk10
WV
Daniel
1984 chevy
k-10
358 Dart block with aluminum heads 430hp/450ft-lb torque
I used a Keep it Clean in my truck. Seemed to be a pretty good harness. You do have to modify the opening.
ceyman72
