wipers squeaking horribly
Jarhead79
Mt Vernon il
Michael
So finally decided my squeeky wipers need to go! Got new blades on and no change, tried lubing the transmission linkages under the cowl with no change, I'm thinking it's actually the parts that come up through the cowl panel and are bolted under the windshield, are there any places to order new, or is junkyard the only place to look? Do these come out from under the dash, and just unbolt the two bolts under the cowl panel to remove?
Georgeb
Wisconsin
George
K10 Burb Z71
Yeah, they come out. You may be able to lune them up and get them to stop squeaking.
Jarhead79
Mt Vernon il
Michael
Do they come out from inside the cab?
Georgeb
Wisconsin
George
K10 Burb Z71
They cone out from in the cowel. You need to take the cowel cover off to access them. Disconnect the linkage from the wiper motor and unbolt the wiper pivots and the whoe works comes out through the top of the cowel.
jturner
