wiper motor will not turn off!
alexkoss90
bloomer
alex
k5 blazer
Have a 86 k5 and the wiper motor will not shut off unless I unplug it. Have replaced motor and switch but same issue occurs. Could this be caused by the box in the steering column the switch goes into or should I be looking for a short/ burnt wires of some kind? Anyone else ever have this issue?
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Most likely the wiper switch itself in the column. Raylanr and I are having the same problem on his crew cab and I've diagnosed it as the switch.
Two likely causes:
1. Park switch is bad or there is a short to ground in the wiring (usually in the column)
2. If you have intermittent wipers, the pulse module may be bad.
Diagnostic for non-stop wipers:
Tommyutah
