wing/vent windows
chengny
I just called my friend Jim at Granite State Glass.
Jim says that the rubber between the vent glass and the steel frame is on the shelf (at any auto glass place). That I kind of figured.
What I didn't expect was that the rubber does not come pre-formed in that U shape. It is a flat strip (the thickness varies with the application) that only takes on that U shape when the glass is pressed into the frame. It is heated and forms a water-tight seal when pressed in. The width is oversized and any excess is trimmed after the bond sets up.
Knowing that I am restoring an old truck, he offered a word of advice:
If you are shooting for a mint condition end result on the vent window, remove the glass frame from the rest of the bracing and bring it (along with the glass) to the shop before you do the final steps. In other words, don't do your final finishing until after the glass is locked into the frame or you'll probably end up doing it over.
The reason is that, the process of jamming the glass into the frame is violent. It almost always results in some scratching and chipping of the frame finish (be it paint or chrome).
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
Good to know, i will check with some of the local places, hopefully i can rebuild both sets and have a spare
Sent from my Nexus 7 using Tapatalk
chengny
Spare? Brandon - don't you have faith in your work? If you do a real good teardown and rebuild. Then properly coat the steel parts - you'll be shaving with that truck before those vents come undone.
Complete vent window assemblies are still available from the dealer. The cost is insane - about $450 each.
If you make two nice sets, pick the best for yourself and sell the other set. I bet you get $400 easy (for a set).
After this you'll be an expert. Think about it, you could go to the JY, pick up a couple of sets for $50. Bring them home, restore and sell them for another $300- 400.
Before long you'll be living like a rock star.
flyboy1100
UsA
me
k1500
lol.
flyboy1100
UsA
me
k1500
Anyone know for sure if the vents from a 90 suburban will fit my 86 truck? I hope so, got just the drivers side today and it is nearly flawless for 24 years old, even the rubber is still in great shape! I'm hoping the right side is equally good
Sent from my SCH-I605 using Tapatalk
flyboy1100
UsA
me
k1500
well the right side is even better! hope they fit
chengny
Looks good. OEM part number for left hand vent window assembly complete is 15634471.
Here is the application chart:
flyboy1100
UsA
me
k1500
Yay! I'm really surprised by the shape of these. I wonder if they were never used? Will post pics later.
Charkmapman
