Windshield wiper stalk problem
iamtherealJayy
Tennessee
V20, K10, K10
Oh yea no doubt about it majority of it everything was original when I got the truck. But I’d rather replace it all myself and do it right than deal with someone else’s Hackery. So the wiper motor sounds like the issue?
No.
iamtherealJayy
Tennessee
V20, K10, K10
Oh… than uh what could be the issue?
SirRobyn0
Rob
Looks like Taylor says no, but I say yes it is the wiper motor. Here's my thought.
Like I said in my first post, based on the failed park switch at the shop the first thing we'd do is replace the motor and see how much that fixes. That will fix the park issue, but it may or may not fix the delay issue. If at all possible get a WIA brand, new replacement. If you can't get one of those and have to get a reman unit, don't get a cardone, the trouble is cardone makes a lot of the "house" brand remaned wiper motors. Honestly if you can't get a WIA unit locally order it off amazon or somewhere else online.
gmbellew
Kansas city
glen
suburban 1500
I recently bought a WAI motor from partsgeek.
iamtherealJayy
Tennessee
V20, K10, K10
WIA is about $80 off partsgeek. I’ll look into it some more if that seems to be the issue.
gmbellew
Kansas city
glen
suburban 1500
you can use the procedures I posted earlier to troubleshoot. but if I were a betting man, I'd put a little cash on the motor being all or some of your problem.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
I'm going through a similar troubleshooting process with my truck. I only have one speed and originally it was very slow and would not stop at the bottom. I swapped in the WAI motor and cleaned up the threads where the motor grounds. I now have a decent low speed and it parks like it should. But I only get one click on the multifunction stalk so I have bought a new wiper switch, turn signal canceling cam, ignition switch, lock cylinder, etc. If I have to dig that deep in the column to get to the wiper switch I might as well replace everything else while I'm in there.
I was saying no because I didnt like his logical flow, you guys say its probably motor, that may be, buti still advise determinign that is the true issue. for example should peel it off, check that ground, check the linkage check under the cap etc etc
86 SCOTTSDALE
Oakham MA
Armand
I had same issue with parking wipers and it was the contacts for the park switch connector. Unplugged connector, cleaned contacts at end of wire, plugged back in and problem gone.
LateOnTheBrakes
5.3-Swapped 86 CUCV
Virginia
Joshua
CUCV
For what it's worth low speed and park were resolved with a new wiper motor and cleaning up the threads where the motor grounds. I replaced the wiper switch inside the column yesterday and now have low AND high speeds.
SirRobyn0
Rob
Well IDK if the OP is still watching this thread or if he bought or installed a new wiper motor, but I for one am glad to hear your report! It's not much fun digging around in these steering columns, but well worth it to get properly functioning wipers.
iamtherealJayy
Tennessee
V20, K10, K10
I’ve been reading the posts but wipers are least of my worries right now lol. Truck isn’t even driveable. Steering is having problems. I posted on the other thread about it.
scawdrey
