Windshield installation
Wallace6
Wyoming
Ray
Suburban
Anybody have a link to a good windshield installation? I live very rural so I will have to order one, hope it shows up without a crack and install if my self. I've done a few windows but any advice is very welcome.
Thanks
fast 99
Spokane, Washington
Assume 87 sub? Unplug radio antenna and remove mirror. Remove center outside locking strip then push glass out using your feet from the inside. Make sure you have eye protection on just in case. Clean grove the old windshield was in then gently lay new glass in bottom channel. Start working the weatherstrip over the glass with a plastic bone. Use windshield cleaner as a lubricant. May have to tap glass down to lock it in, use your palms flat. Glass is actually quite hard to break if pressure is spread out. Then use a strip tool to reinsert the locking strip. Some people use sealant on the bottom edge, but I don't. Makes subsequent removal and clean up harder.
tool
SirRobyn0
Rob
Also don't forget that there are drains in the bottom corners of the windshield frame, if you use sealant you need to make sure you don't block those drains. I know a glass guy so he did mine, he did not use sealant, and said he normally doesn't unless the windshield channel is in rough shape.
FireTruck1984
Michigan
1984 and 1984
Thanks
3M makes a great kit for windshield installation.
Scott91370
Burleson, Tx
Scott
Sierra1500
So does SafeLight, they come in a van. Lol
So does Home Depot...in the rope section.
Honestly, I paid to have mione dine. Guy charged me $200 to install front & rear and redo the rubber on my vent windows (I supplied the parts). Saved me a lot of time!
Never again will I attempt a windshield install in one of these...or anything for that matter lol. Me and a buddy tried putting one in his '73. Broke the first after a few hours of struggling and had to start over. Took us like 9hrs total.
nbkk43f
charlotte, nc
Nick
I just did my first windshield and back glass install about 6 weeks ago. I'll be honest, I wasn't looking forward to it. I watched several videos online, including the two posted by FireTruck1984 above. All in all, the process went very smoothly, with just myself installing them both - I believe my wife helped me initially set the windshield in place.
You didn't mention if you're going with the deluxe (locking strip) or standard (no lock strip) seal - I had both options for my '77 and went with the lock strip style.
I'd recommend Precision for your gasket manufacturer. As for the tools, I relied on set of plastic trim removal tools, spray away foaming glass cleaner, windshield suction cups, a small plastic dead blow hammer (initial seating of the gasket in the corners), locking strip tool and patience.
Use plenty of the glass cleaner to help things move around easier - especially when it comes to the locking strip. The locking strip went way easier than expected - once you get the feel for it, it goes pretty quickly.
Windshield probably took me 2-3 hours to do - back glass was a bit more of a challenge in my opinion (suction cups came in quite handy for helping "move" the glass around), and probably took 3 hours.
Here's another video from Precision.
Good luck man!
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Hopefully it's easier than the rear slider I put in mine. OMG, what a PITA!
Man! That’s not what I wanted to hear my back window works fine just doesn’t have any of the rubber pieces in it. I was thinking of replacing it maybe I’ll just leave it.
GP2024
