Windshield antenna connection
Trucksareforwork
Spartanburg SC
Geoff
I had a new windshield installed this week and the plug for the antenna is too close to the gasket to get the snap fitting of the antenna wire into the button on the windshield. I’m thinking this is a job for an exacto knife. I’m going to cut a bit of relief in the gasket.
Anybody every run into this problem and have a better solution?
Trucksareforwork
Spartanburg SC
Geoff
I’m thinking the answer is nobody!
Haven’t had time to address this problem yet. I will post back when I do. Here’s a picture of the challenge.
fast 99
Spokane, Washington
Kind of, the windshield I just got locally that button was lower than the old one. Still able to plug it in without modification. It just kinked the lead more than normal.
Snoots
Roger
Jimmy Sierra
Smear a little dab of anti-seize on it and use a piece of wood to 'massage' the button on.
84GMCSierra
Central Arizona
C2500
I used duct tape to hold mine on. My truck(84 Sierra, Base model) had a fender antenna originally. It was cheaper to buy a windshield with the antenna in it, than not
dvdswan
Port Orchard, WA
Dave
Get a 1" x 1/4" piece of steel (with no sharp corners or edges) and gently push the gasket down away from the connection. Also massage the gasket down where the connection band goes into the dash. Then use @Snoots suggestion.
Terry Wilkerson
Kansas
Terry
GMC 1500
Does anyone rember the thread recently about a nation wide windshield Installer who does squarebody windshields? I need the name of that company.
Thanks.
M37M35
