Will 30 spline ring and pinion gears work with 28 spline axles?
84 Shorty
Grovetown, GA
Andrew
Im wanting to change my gears from 4.10 to a 3.42 or 3.73. All the ring and pinion gears I am seeing are 30 spline. More than likely my axles are 28 spline since they went to a 30 spline on the 88 years. I have an open rear end, so will 30 spline ring and pinion work? I think I said spline enough in this post
The ring and pinion don't care if it's a 28 or 30 spline carrier.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
8.5 and 8.6 are the same, just make sure the gear set you buy matches the carrier break of your current differential.
84 Shorty
Grovetown, GA
Andrew
4.10s use the same carrier as 3.73 and 3.42 gears I believe
crazy4offroad
Curt
K-10
350/SM465/NP205
A reputable vendor will make it clear what carrier their gears are made for. Depending on the axle 4.10 and up are considered "thick" gear sets designed for 3-series carriers.
436'd skylark
VT
Joe
2500HD
Durajunk
The pinion gear has on an 8.5" rear is 30 spline. That might be what's throwing you off. Lots of sites list that spec as well
87R10_Cruising
