Wide rear wheels.
chevyninja350
Illinois Near St. Louis area.
Andrew
I am new to picking out wheels and tires, I am hoping to get some pointers. I have a 1985 Chevy C10 fleetside long bed, I am looking to run wide rear wheels in the rear. I want to run the widest possible wheel without tubing the bed, I want a 15-17inch Rim with a lug spacing of 5x5in (5x127). I want the wheels to be flush with the outside of the bed. Any ideas on wheel offset and width I should run?
This is a street/strip truck.
If you have a similar setup to what I am after, feel welcome to post your wheel brand, part #, etc.
Scott91370
Burleson, Tx
Scott
Sierra1500
I have this wheel: https://www.summitracing.com/parts/usm-u11118957352
Specs: Rambler U111; 18 in. x 9.5 in.; 5 x 5.00 in. Bolt Circle; 5.25 in. Backspace
and measured last night because I wanted them further out as well. From the edge of the lip of the tire to the inside of the fender (where it would rub if the truck tilted enough) was a full 2".
You're going to have to go pretty wide or get a lot more backspace to fill up the space. Maybe 12"-13" wide - but it will look great!
Craig 85
Nashville, TN
454/TH-400/NP205
This truck has 15×8″ in the front with a 4″ backspace, 245/60/15 tires. The rears are 15×10″ with a 5″ backspace, 295/50/15's.
78C10BigTen
pennsylvannia
C10 BIG TEN
Hot truck!
That setup looks great @Vbb199
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
on my rear 20's 295-45-20 is the widest i can stack in those OEM fenderwell! ;)
What gear ratio and transmission do you have with that setup
Im trying to find a suitable setup to run in my big block c10 with a th400
Bennyt
Surprise
Ben
Thanks for all the replies. I think I found the wheels I'd like to get, but I still have to figure out backspacing. I'll post what I end up getting.
Here is the wheels I'm looking at: https://www.cragarwheel.com/shop/15x12-5x5-series-61c-ss/
Some tire shops will let you rent/ borrow a wheel right tool from them to measure. You can also make a tool in a few minutes with a couple pieces of scrap wood. One piece bolts to face of drum and the other piece on top like a T. You just keep trimming until you have the height, width, backspacing figured out.
K5Chris
