Who has rebuilt their vent windows?
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
I need to do mine, and I took one apart and it seems kind of complicated lol.
Jrgunn5150
Ionia Mi
J.R.
6.slow
The mechanics of the plate and spring are straightforward enough, the seal I have seems to be a good bit longer than it needs to be.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Pics of the aforementioned part......
Jrgunn5150
Ionia Mi
J.R.
6.slow
I'm still at work, I was just idly thinking if I put the windows back together I could get it out from the stupid cover it's under lol.
I'll get pics when I get home, I still have one put together, and one apart. I'm fairly confident I have mismatched doors, with one being a 81-91 door.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Double check whether or not you have one or two piece vent seals. Mine's an '87, and it had two piece seals. As far as I can tell, it has the original doors, and I've also seen an '89 part that had two piece seals. The part that you have to be most careful is the removal of the frame from the door to avoid hurting the main window glass. Same goes for replacement, but you get an idea of how it works once you've taken it out. Also, it's important to keep track of the hardware that mounts the window to the frame and to remember the order and manner that all the pieces go back into place. Otherwise, it's fairly straightforward.
84 Shorty
Grovetown, GA
Andrew
Since we are on the topic of vent windows. I just rebuilt mine and ordered glass from LMC. The hole is too small in the glass for the locking handle to go through. I emailed them, we will see what they have to say.
Jrgunn5150
Ionia Mi
J.R.
6.slow
Keep us posted, spring will come to Michigan some day and I'll find all my parts or buy another set to rebuild lol.
trukman1
USA
Gary
K5 Blazer
5.7 L (350)
I think 1A Auto sells them already redone with a core charge if it seems too risky or time consuming.
Camar068
10 yrs Air Force
didn't someone do a step by step on here? That or posted a really good youtube video link. I still have the seals to do mine that I bought before the engine went out and I got skewed in another direction.
Jrgunn5150
Ionia Mi
J.R.
6.slow
Mine are still in a box lol, one is 85% done, need to get on that before winter, again lol.
eskimomann209
Modesto
Marcus
I thought it was a pain in the a**
But a little heat from a heat gun and some silicone lube helped
Bowers31
