Which 383 Crate?
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I’ve been kicking around the idea of something with a bit more grunt than my current 350. I thought about BBC, Cummins, etc. However, I just put custom leaf springs on built for the weight of a small block. So now I’m looking at a crate 383 for my truck.
The two manufacturers I’ve been reading reviews on are Blueprint with this engine:
…and West Coast:
They’re pretty close in power/tq with the slight edge to west coast. Close enough that it’s not a big consideration.
The price difference is approximately $700. The biggest difference is the warranty. Blueprint’s warranty is decent for a crate @ 30months/50,000mi. West Coast is pretty dang impressive for a crate @ 60mo/50,000mi.
Anyone have personal experience with either?
Mofarmer
Missouri
Mark
I'll be following this closely as I'm in the market for crate engine also!
FireTruck1984
Michigan
1984 and 1984
GM Performance 383 Stroker EFI Turn-Key Engine 450 HP
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I already have everything new to pull off of my basically new Chevrolet L31r crate engine including ProFlo4 efi.
That 383 is a few points down on compression and I’m guessing the cam favors hp over tq.
…and West Coast:
I've never heard of the westcoast one. FWIW I've seen them use the blueprint engines several times on Engine Masters and roadkill. They have always made more power on the dyno than advertised, which in itself is pretty good. I also like that they run all their new engines on the dyno to make sure they are initially broken in right and make the advertised power. Nothing worse than getting a brand new crate engine, installing it in your vehicle, firing it up for the first time and have no oil pressure or it eats the cam on break-in.
Craig 85
Nashville, TN
454/TH-400/NP205
I did the GM engine in my truck only because if there was an issue, I could just go to the local dealer and have them do any warranty work. I didn't want to have to potentially pull the motor at my cost, send it back to the vendor and "trust" there option of a failure.
bigcreek
