Where have you put oil and temp gauges, pics please.
Kim Burke
Northern IN
Kim
C1500
I don’t want to rely on factory gauges for oil and temp. One way to fix that is to upgrade, however, I’ve always liked the looks of stock instrument clusters.
You guys are smart , where have you found to install a 2” gauge “out of the way” but still able to seen?
POST SOME PICs’ please, GO!
I haven't found a good spot, lol. In one truck I had, I put an oil pressure gauge at the bottom of the dash, to the left of the steering column. It was a terrible spot for easy viewing, but it was out of the way.
In a current truck, there's a 2-gauge panel mounted directly below the radio. It's easy to view, but looks odd because they are facing up. I'm not crazy about it, but they were put there by the original owner when the truck was new. I can get a picture of that setup.
Shorty81
Baby Boomer
North West ohio
Darren
All mechanical gages, they are in front of stock gages.
rpcraft
Robert
LS 6.0 364 CID
I found a really good spot almost like it was made for gauges like that, just to the left of the speedometer There are 4 round cutouts, sometimes they have a clock, oil pressure, water temp, and believe it or not, sometimes even a Ameter....
77 K20
Montana
K20 5" lift
HT383 fuel injected
Since I don't have AC I had that kinda worthless cubby on the upper right of the dash. I was able to put 2 gauges up there.
I believe others that had the vent there removed the vent and did the same thing.
77 K20
Montana
K20 5" lift
HT383 fuel injected
@Honky Kong jr
He was the one that modified the vent: (borrowed his pics here from another thread). Great looking work!
rpcraft
Robert
LS 6.0 364 CID
You guys must have it good to never need anything but a heater. I need my 4 season air, lol.
QBuff02
Central IL
Quincy
here's how I did mine. Not the final product, because eventually when I redo the interior I'm going to make it more custom, but this will still pretty much be how it's laid out.
rpcraft
Robert
LS 6.0 364 CID
Almost as if they were were made to go there, lol!!!!
You know the only thing I ever read is that having them flat on the bezel makes them a little harder to read while driving. Any feedback on that? I've been fine with the idea of stock gauges and if I really want a tach I was just going to put one of the mini ones up on the dash by the A pillar. Back in the day when I had my 77 I put it on the steering column but got tired of the cables being loose, to accomodate shifting the gear selector.
When everything is as it should be, all of the needles should be pointing up.
Kim Burke
Northern IN
Kim
C1500
Thanks for the responses.
QBuff02
Central IL
Quincy
Truthfully, I don't think it's an issue at all. If I drive with my left hand at the 12 o'clock position it obsures them just a little bit, but no more than it would with the factory gauges in those positions. As for the tach, I have mine up on the dash just to the right of the kickout for the gauges. Some don't like it there or on the dash at all, and some do. it all boils down to personal preference I think.
MikeB
North Texas
AutoMeter Sport Comp 2-1/16 gauges. Getting things back together after new wiring harness installation.
scawdrey
