When do you need a longer front drive shaft?
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
Wondering what the max usable u-joint to u-joint measurement is for the stock shaft. I've got a 3"-ish lift and am about to move my axle forward an inch or so but I have no idea how far out the shaft can go before it starts getting sketchy.
Craig 85
Nashville, TN
454/TH-400/NP205
I just did a 3" lift on my K30 and had to add about an inch. I got lucky in a way, the slip joint was bad and had to be replaced. The new one made up the difference.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Depends also how you are using your rig.
Are you going long travel? Drop the anti-sway bar and longer shocks, Ford shock mounts thing?
Because needless to say... but say it anyway, the extra droop and travel will need not necessarily a longer shaft but longer splines on the slip joint.
Craig85 kinda touched on that. His new slip joint was longer and just like that he was dialed in.
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
I'm not doing anything wild in the immediate future. Just a lift and shoving the axle forward. I figured I was ok right now, but I couldn't find any answer to the question anywhere so I figured I'd try and ask.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Right on.
Keep us in the loop please, I want your take on how the truck handles/feels with the axle moved forward. Good call.
CSFJ
As opposed to lengthening the shaft if it doesn't need it?
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I lifted mine 6” and had to shorten mine go figure.
Did you turn your axle tubes? Point pinion up or something? Upgraded CV and universal resulting in... a shorter shaft?
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
Right on.
Will do. Next paycheck I'm going to order axle relocation plates for the front and axle shims for the back from ORD along with some new brake lines.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I have a 1.75” spacer between my transmission and transfer case, shackle flip and relocation plates
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Ohhh, yeah. I was thinking front driveshaft... as this thread is about a front shaft.
Thanks
87POPS
