What's this look like to you?
adaml23
Decatur, IN
Adam
Scottsdale
I'm trying to figure out what wheel/tire/stance to go with and I think I found the perfect model. Problem is, I don't know anything about it and just happened to come across the picture. Anyone know anything about it or have any guesses on it? Looks to have Eagle Alloys or M/T rims. What would you guys put the lift at (if any) and rim/tire size at?
I'm almost 100% positive it's stock height (maybe with new springs though) with 33's. Probably a 16x8 wheel with about 3-4 inches of backspacing. I simply called them "33's" but technically, the tire size is likely a 305/70/16. I think they look wider than a 285/75.
adaml23
Decatur, IN
Adam
Scottsdale
Would 305/70 fit on a stock suspension without rubbing? I figured they would rub. What would be the best backspacing option for 305/70 so it would fit without a lift?
firebane
Calgary, AB
Curtis
Looks like that truck would never see any time off road at all and wouldn't run into any real issues with rubbing.
Yeah, it should be fine if the truck isn't used hard off road. Using an 8 inch wide rim or narrower.
77 K20
Montana
K20 5" lift
HT383 fuel injected
They are 285/75 R16s on a stock height K20. Belongs to @DesertBob over at 67-72chevytrucks.com and he is also a member here.
Google search is your friend...
So there's your definate answer. I was with bucket. Stock height and 33's. It does certainly have a very nice stance.
HectorGarcia415
