Whats in my rear end?
bbc
Ark
Cory
Hey guys, i gotta 83 stepside project, the 1st thing im wanting to do is make it posi (for burnout reasons) im gonna get a spool and 4.11s for it but idk if its a 8.5 or what? its a 10 bolt. and is it 28 spindle?
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
K-10
350/SM465/NP205
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
HEy Cory what part or Arky you in?
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Asking what is in your rear end is not always a safe question around here...:roflsquared:
bbc
Ark
Cory
You would need to set up those gears, if you've never done it before I dont advise it. The cheaper route would be a slip in spool like a Yukon or a slip in locker like a Lockright, like the ones here...
http://completeoffroad.com/c-65253-...s-carriers-g-m-8-5-lockers-positractions.html
You'll have to pull an axleshaft and find out for sure if you have a 28 or 30 spline before ordering just to be safe.
ive been looking thru summit and a spool, c-clip eliminatiors and gears rounds up to like 400 bucks with out the bearing kit, is it that hard to put a locker in?
smurph20
Brad
Very cool im in Lincoln not but a few miles away. YOu said something about burnout reasons in your first post you gonna try to make it to Westville for the burnout contest on May 5
J Knight
Baytown TX
82 Chevy
350ci
bbc
Ark
Cory
ha i wish i could but the trucks gotta ways to go b4 its road worthy
crazy4offroad
K-10
350/SM465/NP205
A full spool, full locker, or anything you're going to have to bolt the ring gear to is going to have to be set up again. You can do it if you own or have access to the tools to do it. Dial indicator and base, caliper micrometer, ft/lb and in/lb torque wrenches, bearing press, 450 ft/lb impact...
I did a write-up when I did the r&p in my 14-bolt, you can see it here...
http://www.gmsquarebody.com/forum/showthread.php?t=250
...but the setup for your 10-bolt will be a little different. So THIS is why I recommend a slip-in locker or spool, so you dont have to monkey around with setting up the gears all over again on a full spool or full carrier locker.
Kipps5000
