What tach are you running
fowjacob
Lubbock,TX
c3500
383 Stroker
im looking into buying a tach and need some help. would love to see a pick of mounting location to
Driver4r
Nebraska
Trevor
k10,c20
J Knight, it might work for him, But there's times im sure i have her turning more than 7k. Nice clean look tho.
Sorry if i spoke out of turn.
The tach in my monte maxs at 10 i think. And i mount them on the column tube.
chengny
The only time I use a tach is when I'm working on the motor so here is where I mount them:
fowjacob
Lubbock,TX
c3500
383 Stroker
what kind of motor are you runnin
SlickGTP
Houston, TX
I mounted a VDO 2 1/16" in where the clock goes... Really pretty and just about looks like it belongs there. I've got an automatic so I don't really need to look at it all the time, but it's nice to reference every once in awhile.
I can't find the pic of it in the truck, but I know I have one at home.
fowjacob
Lubbock,TX
c3500
383 Stroker
that looks pretty good where did you get that one
fowjacob
Lubbock,TX
c3500
383 Stroker
Thats actually the tach i was thinking about getting. Either it or the white one. I was thinking of putting it on the pillar. how is that tach would you recommend it
SlickGTP
Houston, TX
Picked up the gauge from Summit Racing... Roughly $100 or so...
After that all I needed to do was trim the hole for it where the clock sat, cut a hole in the back of the cluster case and in the gauge lens. Lots of time with the dremel to get it as close as I could. Sits behind the bezel perfectly.
fowjacob
Lubbock,TX
c3500
383 Stroker
can anyone recommend a full sweep 3 3/4 tach that what im looking for i think
Green K10
