What ratio do I need?
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
I'm going to update just because I'm at work wishing I was at home working on my truck. I got both drums, both axle shafts, and the carrier/ring gear out last night. The pinion is going to be fun since I'm not sure how damaged it is. It currently doesn't turn, but I think that's because it's touching the inside of the pumpkin. Overall I don't find any damage to the housing itself, just chewed up bearings and melted ring and pinion gears. The spiders look decent but I need to replace the pin holding them in the carrier.
I finally cleaned enough mud/rust off the outside to get the axle code: BRA that's a '84-'86? 2.73 with a locker. I'm guessing the gov't locker exploded at some point and someone stuck spiders in because it was a cheap fix. No worries, after I get the new gears broken in I'm going to throw a lunchbox locker in it, though I'm not sure which one yet.
Slow progress is still progress in my eyes.
350runner
tx
Ceasar
Way to go! That hard work will pay off :)
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
Well, I found my point of failure. Pretty sure it's not supposed to look like that.
350runner
tx
Ceasar
Yup looks like it took a beating :)
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
Mine didn't look great, but that looks horrible
Sent from my SCH-I605 using Tapatalk
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
That's apparently what happens when you run a rear diff at 70 mph for an hour with no oil in it. There's no gaps between the individual teeth, it's a smooth surface.
Carb'ed Vortec 350
Wow that has seen better days for sure.
77 K20
Montana
K20 5" lift
HT383 fuel injected
Wow- never seen one like that before. :Insane:
flyboy1100
UsA
me
k1500
Shim under my pinion bearing. Makes no sense to me. Also very thin somewhere between .007-.012. I thought average was like .030?
Juanosious
