Pender1
- Nov 12, 2014
- SC
- Brian
- 1986|2014
- K5|1500
- 5.3L|5.3L
My plans changed a little and I'm now going to be getting a 4" lift instead of the 2" that I had planned. I'm trying to determine what I'll have to modify to do a 4". I know moving up to 6" means you have to go to crossover steering, but I'm not sure where the line is on some of the other stuff.
Here are the things I'm questioning:
-brake lines (will a relocation bracket work or will I have to buy extended lines?)
-drive shaft (is it long enough?)
-sway bar (do I need to put in drop spacers?)
-pinion angle (how likely am I to need to shim it?)
-TC drop?
Am I missing anything else? I'm going to be running 33x12.50x15's on a 10" rim.
-TC drop?
