What is this on the intake? Is it needed? Getting ready to tune
Mark Sprenger
South Plainfield, NJ
Mark
5.7L
Hey guys, have a ’82 K20 with the 350 and I swapped out the qjet with an edelbrock 1406. Also have headers on the truck so EGR has been removed. I am trying to get the remaining vacuum lines squared away. Right now I have the PCV tied into the front vacuum port on the carb and the distributor tied into the ported vacuum on the front. Will be hooking up the brake booster to the rear of the carb vacuum. Now my question is in the below picture what is the pipe coming out of this plate on the stock carb? (this isn’t my intake just a pic I found) And do I need it if so what should it be tied into? If it is not needed is there a block off plate I can put in its location?
I know I still have to tie my modulator valve for my th400 into the intake or maybe the right side vacuum port on the 1406 since it is manifold vacuum.
Is there anything I am missing for this swap? Ordered the thrush exhaust system and want to tune the carb this weekend.
I am figuring most of the sensors like temp and all that on my stock air cleaner won’t work because I removed the stock headers. Could I just swap it out to an edelbrock air cleaner?
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
I can't see a pic there.
Jrgunn5150
Ionia Mi
J.R.
6.slow
If you aren't changing intakes, you might need an adapter plate.
74 Shortbed
That's for the choke on a Q-Jet..
K5freak
Ca
Tony
Just leave it as is
sparky77
