What in the f is this bracket for??
meatbag
Kettle falls WA
Gmc serria grande
400 sbc
I'm swapping engine and transmission, pulled my transfer case to clean and paint. I'm looking for hour on Google with image search, cuz this bracket showed up in my pile of parts. At this point I'm hoping someone was ******* with me, cuz I don't know what it is or where it goes. So any advice
meatbag
Kettle falls WA
Gmc serria grande
400 sbc
Okay Where's this diamond attach too?? Please and thank you
meatbag
Kettle falls WA
Gmc serria grande
400 sbc
I'm thinking it was somewhere in the th350/np203 crossmember bracket. Or adapter piece. Mounting bracket ,
Originalthor
Saskatoon Saskatchewan
Scott
Suburban
The holes on your second picture by your fingers look like a transmission mount wear
meatbag
Kettle falls WA
Gmc serria grande
400 sbc
Yeah I agree, okay I'll see if bolts line up
nvrenuf
Mobile, Al.
Unless it’s a 6.2 diesel part (because im not familiar with them), my money says it’s not off of a square body. I’ve messed with a lot of GM tcases and never seen that bracket.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Maybe some older model u bolt plate? The machined surface throws me off on top, maybe for a sway bar link. Maybe like a bronco or scout u bolt plate. Looks like one side sits on the cast housing of the axle like a Dana 60.
meatbag
Kettle falls WA
Gmc serria grande
400 sbc
Thanks Prarie Drifter. Hopefully it's not needed, I'll set it aside for now. When I dropped the transmission and transfer case, there was a crossmember where the adapter meets, pretty normal. I should look under the truck for signs of aftermarket mods.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
That looks like a trans mount relocator. Old aftermarket adapter piece for if you changed trans to one thats a little longer, but didnt want to relocate the crosmember...
Just a thought.
meatbag
Kettle falls WA
Gmc serria grande
400 sbc
Yeah im thinking something like that also, cuz a set of holes match the underside of the transmission for a 2wd rear mount. At this point I'm convinced it's not going in my truck, unless I on its location. Thanks ayWoSch
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
The trans mount idea sounds more plausible, as an adapter.
82GMSQUAREDIESEL
Ryan
K2500
6.2L Diesel
drop bracket for the 205 on a 6.2 with muncie... I'll post pictures when I have time to get under mine
jake26104
