What Diff is This?
GregL
Palm Springs, CA.
Greg
K 20
1977 K20
Thanks, Greg
Original rear brake lines, you don't see that around here. You can even see where there used to be a label on the diff cover. I wonder what it used to say?
GregL
Palm Springs, CA.
Greg
K 20
Yes, gotta love SoCal environment for vintage vehicles.
Politics... not so much, but the climate is badass!
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Its crazy i saw it for a brief second and immediately said 14 bolt FF!
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
That is by far the best rear diff made by GM. Easy to set up gears in it too.
GregL
Palm Springs, CA.
Greg
K 20
I need to replace the passenger side axle. Seal surface is worn and leaking.
It's a full floater, so the axle shaft doesn't ride on the seal. The seal is in the back of the hub and rides on the spindle.
GregL
Palm Springs, CA.
Greg
K 20
Can you tell me which diff my front one is as well?
That's a Dana 44
GregL
Palm Springs, CA.
Greg
K 20
It keeps eating seals on that side. 3rd one in 18 months.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Are you talking about the hub seal? You may have a bearing or a spindle problem.
* Which is pretty much what bucket said. Sorry for not reading thoroughly.
There might be a nick or gouge on the seal surface that can be removed with a file. If it's too badly damaged, you can get a Speedy Sleeve for it I think.
It would be no big deal at all if there is a 2-piece type HD seal available, like what the big trucks use. But I'm not aware of any.
btrain04
