Weird idol and no power when driving
blairsj
California
Steven
k5 Blazer
5.7 Tbi v8
Have a 1990 TBI 5.7L v8. Starts up fine but after warmed up starts idling funny. Got a new distributor, ignition coil, EGR valve, EGR control solenoid, injector spray fine, PCV valve, throttle position sensor, map sensor, idle air control, oxygen sensor, and and did a throttle body repair kit.
After it’s warmed up, I noticed a ticking sound coming from the engine compartment on the passenger side not sure what that is.
Any help would be grateful. Thank you in advance.
Chuckd84
Sedley Va
Chuck
Silverado K20
Have you checked your fuel pressure or for any exhaust leaks upstream of the 02 sensors?
blairsj
California
Steven
k5 Blazer
5.7 Tbi v8
Fuel pressure is good, and no exhaust above o2, just a pin hole at the y pipe
gmbellew
Kansas city
glen
suburban 1500
could be a big vac leak and the clicking sound is the stepper motor on the IAC bottoming out at 0 IAC counts and all the way closed.
is it idling high?
blairsj
California
Steven
k5 Blazer
5.7 Tbi v8
Also no obd codes
fast 99
Spokane, Washington
Were all the parts tossed at it in an attempt to fix the drivability issue? When did this first appear? Check vacuum, excessive engine noise may set off the knock sensor. What was the fuel pressure? They will not run properly at the low limit. Any exhaust leak pre-O2 can result in incorrect fuel trim.
Lack of check engine light doesn't surprise me at all. Those early systems were basic, that's why they are usually dependable.
blairsj
California
Steven
k5 Blazer
5.7 Tbi v8
Not sure where the rpm are but it drops low like it wants to cut out then goes back up. I was thinking the clicking was the IAC so i put my ear right by it and it sounded like it was lower, also put my hand on it to see if I could feel it clicking but felt nothing.
It is in my plans to get a tech in the future
blairsj
California
Steven
k5 Blazer
5.7 Tbi v8
Some parts needed changing others i just put on because it old. It started a few months ago, really notice it when I drive it up hills like it has no powers pedal to the floor and just barely gets up it. I haven’t checked the fuel pressure at the throttle body but in line after the filter and it was spec. Pressure.
blairsj
California
Steven
k5 Blazer
5.7 Tbi v8
How would I go about checking vacuum? Looked at all the line and checked a few all seem to be in good order, no cracks that i can see.
gmbellew
Kansas city
glen
suburban 1500
All you need is an OBD1 blue tooth cable and thr ALDLDroid app on a phone or tablet to see what the computer seems from the sensors. Plus fuel trims, knock counts, etc. All in your looking around $100 or a little more.
With the losing power on hills comment, I am guessing large vacuum leak. Maybe even the intake manifold gasket.
gmbellew
Kansas city
glen
suburban 1500
Put a vacuum gauge on the EGR solenoid port on the TBI. The solenoid shouldn't be trying to open at idle.
Use a mighty vac to make sure lines aren't leaking and are holding vacuum.
You can also measure voltage at the MAP sensor or use the aforementioned OBD1 cable and app to watch MAP values in real time.
blairsj
California
Steven
k5 Blazer
5.7 Tbi v8
Okay I will look into the obd cable and app, thank you. I’m sure that would be a great tool to have in my arsenal
blairsj
California
Steven
k5 Blazer
5.7 Tbi v8
The egr port you are talking about is the one in the middle of the throttle body?
Camar068
10 yrs Air Force
@Billy where's he at when you need 'em.
gmbellew
Kansas city
glen
suburban 1500
I think it's the middle one. check the sticker on the core support to be sure
you can also spray carb cleaner around in suspected leak locations and see if the idle changes. if it does, you found your leak.
SkreetKilla
