Water pump bolts
Skweegle89
Oklahoma
Anybody know the correct bolts to use for a long pump? The bolts I have are 3 different lengths and rusty so Im going to replace them. As I look around the internet I find some that have 3 the same length and 1 quite a bit longer, some with 2 long bolts and 2 short bolts and I just need to know which ones to use. I have a bin full of grade 8 hardware but Im just not sure of bolt length. While I'm at it, do I need to seal these bolt threads with anything?
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
The bottom hole in the block on the driver's side is deeper, it will take 1 7/16" of threads before the bolt bottoms out. The others will take 3/4". Add an inch and a half for the depth of the holes in the pump.
The pump I measured is aftermarket but I'm assuming others are the same.
Skweegle89
Oklahoma
Thanks for the help.
firebane
Calgary, AB
Curtis
Yes toss some thread sealant on those guys as they do enter water jackets.
Although one position will take a longer bolt, it's not needed and the factory didn't build them that way. It's just supposed to be 4 matching 3/8 bolts. IIRC, they should pass through the pump and have about 5/8 inch of threads protruding.
chengny
X2 as Mr. Bucket says - 4 bolts, 3/8"-16, 2" long.
Fastener size/quantities for SBC:
Skweegle89
Oklahoma
Thanks for that. I ended up using 2 1/4" grade 8 bolts and they worked fine without bottoming out.
Rusty Nail
Rusty
350sbc
Yeah but now the bolts have entered the water passages and are restricting and obscuring flow....
I only run 1.75s. You have half an inch x4 (2 inches worth) of hinderance... just sayin.
LoL..
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Only one hole is open to the water passage, the others are blind. If you use 1.75" inch bolts that gives you just four threads on each bolt (one inch total) holding your pump on.
Skweegle89
Oklahoma
They all seemed to work fine, I'm just a little nervous about the bottom pass side. It's either tight or bottomed out, but it's the same depth as at least 2 others right? It just didn't flatten out my lock washer like I would have liked, but seems to be tight.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
If it bothers you grind a smidge off that bolt or put a second washer on.
Skweegle89
Oklahoma
Don't know why I didn't add another washer. That's why they pay you the big bucks. Thanks.
Rusty Nail
Rusty
350sbc
Yep. Makes sense to me...rather than run into coolant flow or have different sized bolts. I got the same thing goin on with my intake bolts.
Posted mostly for the lulz yet the point of theory remains valid IMO.
What's the purpose of 800 unused threads inside the engine? These ain't Dodges...
It's unsprung weight!
firebane
Calgary, AB
Curtis
Intake is completely different. If you put longer bolts through a few of the holes you can actually pinch off push rods.
Skweegle89
Oklahoma
lol bash ferds all you want, but theres nothing bad that can be said about the 70's/80's model dodges.
TheDustyDresser
