Water leak help!!!
charlesg
wisconsin
charles
k3500
91 dually, water dripping from behind the dash on the drivers side, right tight to the kick panel.
Thanks!
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
I would guess windshield.
73c20jim
Tombstone, AZ
heater core??? if it ain't raining.
Cuba
Likes to work alone in her woman cave
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
Use a hose to test.. or if you have access to air, spray soapy water on the outside and blow compressed air around seams around exterior as well. You'll see & hear the difference and sometimes bubbles depending on if hit right.
charlesg
wisconsin
charles
k3500
Are they any holes under the vent thing where the wipers are that could leak?
Cuba
Philly, PA USA
Cuba
S10 Blazer
4.3ltr TBI
No, not to the interior. Only windshield seal
PrairieDrifter
North Dakota
Mason
scwaters
Chester Springs, PA
Sunny
K10 Shortbed 4x4
Drain holes on the fresh air trough in front f windshield. Drain hoes on a sun roof if you have one.
86 Belgium Sub
Antwerp - Belgium - Europe
Kurt
Chevrolet Suburban C20 Silverado
5700cc - 350cu - LT9 - 700R4
Hello,
I had the same issue in the past weeks.
A lot of water coming in on the driver side, less on the passenger side.
Seemed to be rain water crawling between rubber and windshield.
Solution was removing chrome window trim and adding sealant between window and rubber. Re-install chrome trim and finished. Good luck !
highdesertrange
kalifornia
mike
k30
the drain for the vent is plugged up. highdesertranger
Snips71
