Voltage issues on a 1987 R1500
murdrd87
Ooltewah
Brandon
R1500
I own a 1987 R10 truck, I've been having issues with the ignition moudule blowing out, the voltage will spike to 18 volts and just kill the module. I've replaced the Coil, ignition module, disributor cap and rotor button, it has new plugs and plug wires. Back in January I put a new aftermarket intake manifold on the truck, doing this I was not able to bolt the coil back on the manifold because of no room. I mounted the coil by the distributor on the firewall, everything else on the truck was the same. Would repositioning the coil be causing the issue or can you mount the coil in any way. I've never had this issue before. I wouldn't think mounting the coil at an angle would matter, any help would be appreciated. Also I've never replaced the alternator either, could there be an issue with that. Everything else on the truck has been replaced.
robert8096
Goose Creek SC
Robert
That sounds like a bad internal regulator in the Alternator.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
What he said :waytogo:
rich weyand
Bloomington Indiana
Rich
^^^ x2. Also, you can replace a stock 10SI or 12SI alternator with a 12SI that has amperage up to 130 amps. I replaced my 55-amp 10SI with a 94-amp 12SI. Same size, same connections.
highdesertrange
kalifornia
mike
k30
x2 on what everybody said. you should not be seeing 18v no matter what you did to the ignition. btw I would run a new ground on the relocated coil to the engine. highdesertranger
aaron06
