Very stiff steering...gear box?
shndags
Idaho
Shanda
I have a 1977 c10 2wd that came stock without power steering. It's always been really stiff to steer wich wasn't a problem in my 20s, but now I'm forty-and a couple sprained wrists and bad back later I'm looking to ease it up a bit. What can I do to make it easier to steer without totally conferring to power steering? My son has the same truck but 72 and his is way easier to steer....installing a different gear box maybe?
firebane
Calgary, AB
Curtis
What exactly is wrong with power steering? Doesn't hurt nothing and in these trucks its a godsend.
87ChevyR10
Kansas
NA
NA
NA
He doesn't have PS. If memory serves, I believe there is a way to tighten/loosen the stiffness, but I am uncertain how.
yevgenievich
Viktor
sad
very sad
less sad
Gearbox or the wrong length idler arm could be an issue. Power steering is easy to convert to and would be even easier to drive. There is an adjuster on top of the gear box that can be usedbto loosen the gearbox a bit. But it will likely introduce slop in the wheel as well.
Georgeb
Wisconsin
George
K10 Burb Z71
I will also vote for a power steering upgrade. It's an easy bolt on affair.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
You cant go wrong with genuine gm power steering lol. Its so nice you barely need a finger to turn the wheel
Jack the front of the truck up off the ground, then turn the steering wheel back and forth. If it still tight to turn, something is seizing up.
Carb'ed Vortec 350
It may also be the type of tire you're running and/or the rim offset. When I bought my '65 c20 in April 2015 the PO's son had passenger tires installed on aftermarket wheels, and it was a bear to steer and drive, even worse in parking lots or manuevering in the driveway. I had a set of tires with E load rating and wheels with better backspacing and after installing them the difference was a whole lot better. It is still firm when turning in parking lots or in the driveway, but not as bad as it was. Power steering is definitely a viable option. When I rearrange the vehicles in my driveway I am always amazed that my '81 c20 is like a cadillac compared the '65 c20. The '81 is power steering and brakes and can be turned with one finger.
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
I used to have an old '61 Chevy with manual steering and was shocked how hard it could be at times. Sitting still in gravel or dirt it was easy but dry concrete or blacktop the front tires might as well have been glued to the ground. Best way I found to turn was to get the truck rolling even just a very little bit in the direction you want to go and the steering is much easier. This still applies to my big truck sitting on 38s with power steering. If the truck is rolling a minute amount the strain on the steering system and frame is greatly reduced. If you do decide to switch to power steering DONT junk your manual box. People who race like them, one less pulley sucking horsepower off their rig. Well, unless it is found that your box is just completely worn out and seizing up. But even then it is still good for a core charge.
donmateo
WI
When was PS standard on these?
joecal
LaGrange Highlands,IL
Joe
C10 stepside
305ci
I had a 60 C10 and it was a bear to steer I thought when I got it. I installed power steering and it was a big improvement and more enjoyable to drive.
reisman20
