Vent window latch replacement
So, replacing the vent window latch is pretty straight forward but I have one question that I'm hoping someone can answer. The chrome knob is held on by a pin that goes through a little hole. What is the magic combination to getting that pin to go into it's hole??
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
after all them kid's we should not have to tell you how to get your little pin in the little hole:sorry: a pair of needle nose pliers and a lil hammer
74propu
florida
austin
5.3 / ?/454 tbi
start the pin in the hole on the work bench then put on window and tap the rest of the way in
donmateo
WI
Since I'll be doing this relatively soon, what did you use to get it out?
I'll try the needle nose pliers and hammer trick.
74propu
florida
austin
5.3 / ?/454 tbi
74propu
florida
austin
5.3 / ?/454 tbi
on a side note I may be getting a 86 c10 long bed bad eng strait body $500
it will save on the fingers and all the bad words
Ok, I got it started via needle nose pliers and hammer once on the window what is suggested for pushing it the rest of the way in? It's pretty snug and wonder if using the hammer once it's on the window runs the chance of breaking the window
74propu
florida
austin
5.3 / ?/454 tbi
lightly tap it all the way in soft taps are you working on it now and on here
Working on it as I type lol
Thinking about possibly channel locks and squeeze it in
74propu
florida
austin
5.3 / ?/454 tbi
you can do that but may scratch up the chrome
Georgeb
Wisconsin
George
K10 Burb Z71
I just tap them in with a hammer.
Ugh....I'm going to try but put a towel between the chrome and pliers. I'll post back with results
81chevyc10
