Vent Window Help!
cah2873
East Texas
Chance
Hello,
I have replaced the seals in my vent windows with seals that were bought from LMC Truck. Installed them and have been driving around for the last 3 months with air leaking in. I have tried tape between the glass and seal and it did not work. I finally discovered that it is leaking on the front track in between the rivets where it causes a slight bow in the seal and then in behind the other seal. I put silicone on this part and it did fix it, however it looks like crap from the outside. My question is: 1.) I am using the correct seal or are there better quality seals out there? 2.) Does anyone know of a glass shop that will permanately put the window in without hinges and etc?
Any suggestions?
chengny
Hello,
Any suggestions?
A picture or two - showing the area where you are getting the leak - might get more responses.
gmachinz
Harnessworx Inc
Iowa
Jabin
Which side? I have (2) LH NOS vent assemblies w/glass available for 81-87....that's the best route imo
cah2873
East Texas
Chance
Ill take some pictures this afternoon.
I put the silicone on both windows. BTW, how much for 1 of the assemblies?
gmachinz
Harnessworx Inc
Iowa
Jabin
The vent assemblies are GM NOS and I have them priced at $450. I'm aware aftermarket seals are much cheaper but this is also a complete assembly-and has been obsolete from GM for many years now.
I'm out of stock on the RH...only (2) LH assemblies left.
77 K20
Montana
K20 5" lift
HT383 fuel injected
I bought the LMC vent window seals and a friend of mine who owns a body shop offered to even install them for me. He said the fit was crap. Mine leaked air. He thought that if I waited till summer maybe the heat would help them take shape better.
Nope. I siliconed them.
Probably not the answer you were hoping for- but at least someone else had your same issue.
There is an expensive option to just remove the vent completely.
https://www.brotherstrucks.com/73-87-1-PIECE-WINDOW-KIT/productinfo/OPWK800/
chengny
Word on the street is: If you don't want to spend the money (or the time to source) NOS rubber for your vent windows, the next best choice is Fairchild Industries.
They have slowly/quietly developed a solid reputation. Look around, it's hard to find anyone that has anything bad to say about Fairchild's rubber seals. Ahem...unlike what folks have to say about the seals that LMC markets.
cah2873
East Texas
Chance
That is what I am reading- the seals from LMC are not as good as other companies. The vent window themselves are in good condition so I may just try to replace the seals once again with some better quality ones. They are definitely a pain in the $$$ to replace them.
TrivTen
