Turn signals not flashing but turn on when I push on the break pedal. Any ideas?
Evan 86 K3500
Utah
Evan
WP29P4A
Nevada
Sierra Classic V1500
Verify that you have grounds, verify they are tight, make sure they are good clean connections. A wire brush/wire wheel works well cleaning connection points. A little dielectric grease keeps them from oxidizing for longer periods of time.
If all grounds are good I would look at the signal flasher next.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Welcome to the site Evan and we need pics of that big block one ton 4x4!
mtbadbob
Montana
Bob
V20
Try a new flasher relay
75gmck25
Northern Virginia
Bruce
Did it just happen, or was it there when you bought the truck?
It’s almost always a broken ground wire, and you have to think of recent work on the truck (where you knocked a wire loose) to narrow down the choices.
First checks
Instrument panel ground up under the dash
Ground for the front harness in each side at the radiator support
Villano
