turn signal problems
fowjacob
Lubbock,TX
c3500
383 Stroker
is the turn signal opposed to turn off as you turn the wheel back if so how would i go about fixing this problem
There is a plastic cam built into this piece behind the base of the steering wheel:
picture hosting
That cam lobe trips the springs (red arrows) on the turn signal assembly and cancels the turn signal, moving the turn signal stalk back to the center "off" position. Some times those springs break, or pop out, or the little white tab holding them in (green arrows) break, and the spring pops out. That most likely is where your problem is for no self cancelling.
free picture hosting
This thread shows what is involved in tearing the upper column apart:
http://www.gmsquarebody.com/forum/showthread.php?t=3085
fowjacob
Lubbock,TX
c3500
383 Stroker
picture hosting
Can always count on 89suburban THANK YOU
90% of the time, those little spring bumpers are whats broke. I usually get replacements from the junkyard so I don't have to replace the whole turn signal switch. I just go around the GM section and take them from steering columns that already have the steering wheel removed.
fowjacob
Lubbock,TX
c3500
383 Stroker
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
There you go!
But it all depends...You can go to the junkyard, get the springs and slip them in your pocket or just get new and know they are new.
fowjacob
Lubbock,TX
c3500
383 Stroker
There you go!
HAHA :roflbow: thats one way
3dbello
