Tuned Port video
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Looks good man! Sounds good too!! :cheers:
Thanks! There`s always room for improvement, so when this one blows, I am pondering either an LSx swap, or an updated TD 6.5......I hope they have a duramax 1/2 ton option pretty soon, or else, I`m stuck with the Detroits, but that`s not really a bad thing either!
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
So tell us about the TPI upgrade, where did you score the parts from? How much did it set you back? How hard was it to get it installed and running right? Did you run into any snags? Looks like it was polished, looks really good dude.
sandrock
Mustang OK
Bradley
2500 Suburban
I'm interested too. I'm going this route with my Suburban, but I'll be running a Corvette LSx PCM flashed with a 2002 Chevy Express bin file, and Vortec distributor. I'll need info like what throttle cable you're using and what if any issues you had with running vac lines and such.
Jims86
Patterson,Ca
5.7 TBI
Found a 91 z28 in the bone yard with a rod through the block, so i got the manifold, evap cannister, AIR diverter valve. My 86 already had an EFI ready distributor. All I hade to do, was Splice into my fuel system, and install a walbro gsl392 inline fuel pump, the return line was already there. And the rest is just swapping out the old with the new. the tuned port manifold installation was as easy as replacing manifold gaskets. Camaro harness and ecm wherever you can find room, mine is behind the glove box, and then I installed 3 bus type fuse holders for the fuel pump circuit, and the injectors(2, 1 for each bank) to a key on source.
For California, I had to split the exhaust and install 2 cats, then it runs into a dual 2.25 in/3" out muffler, to a second muffler in the stock location, with factory 86 dual tailpipes.
nxtlevl
Hutchinson,KS
Ed
Very, very nice..!....:High 5: I love the torque the TPI motors make....granted these motors are old-school nowadays, but I have a blast driving my '92 Z28.....:)
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
That's a real nice conversion there. At first watching the video, I'm thinking start it up already. hahaha, I didn't realize it was already running. Nice. Smooth and Quiet up front. I'm sure you need to elaborate a bit on this convesion. I know several people have suggested they might do a TPI setup, Retro being one of them. I was thinking bucket might have mentioned it too.
GM should have put TPI in the trucks to begin with, it's a great combo. I've thought about doing Crossfire Injection, just to be different.
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
Crossfire is awesome lol
Jims86
Patterson,Ca
5.7 TBI
I don't hear too much about crossfire anymore, but I`m sure improvements could be made to solve any of the issues that people had with them...the only issue I could see, would be parts availability.
If anybody has any specific questions, please let me know, but EFI swaps like this are as easy as changing your intake manifold, whether its TBI or TPi. There are also single plane intakes from Edelbrock, with injector bosses already machined in so you can use all of the GM electronics, and an LSx throttle body. I scored the manifold, harness and ECM for $300, fuel pump was $120 at the time, Camaro fuel filter was $9. Then there are various fittings, which depends on how you taylor your fuel system.
All the parts on hand, this swap took me a weekend. Keep in mind, My 86 drivers side exhaust manifold was already set up with an o2 sensor. I ran on the single cat exhaust for about 2 years, and had the dual cats installed. The best exhaust combo for me, is 2.25 from the manifolds, to a Magnaflow Y pipe(unless you like it quiet like I do, then use a 14" case Dual in/3" out muffler in place of Y), and a 3" In/Out muffler, which resides at about a 45* angle, pointed up over the axle. I have dual 2" tailpipes, just for the factory look of the original 86.
Most of the square bodies have a fuel return line from the factory, so that is one headache avoided.
Manbearpig,
Yup, That was me! Gave you the lower manifold for the early heads for shipping.
kparris
