Truck shuts down...
87Hi-v15HND
chesapeak, va
Daniel
v1500
not sure if I’m in the right forum but I’m pulling into the chic Fila parking lot and the truck shuts down and battery is dead... won’t start back up without a jump. Any ideas?? I mean the truck could run if battery is dead and I don’t think it would just shut down if the alternator was bad... if I’m wrong I’m all ears! 87 350tbi
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I’m thinking your truck wanted you to get a hamburger instead.
On a more serious note, I’d check alternator output right at the alternator and then see how things are at the battery. It may just be a dead alternator, and it would have died a little bit up the road not right then and there.
Rusty Nail
Rusty
350sbc
Srsly?
We're not going to have any better luck diagnosing something like this over the internet than you are standing at the hood.
What a fun game.
I think it may be your leaking halogen fluid onto the alternator belt or maybe the e.g.r. filter is clogged...or maybe the truck wanted pizza. Does she ever like a Big Mac?
But seriously. When was the last time you changed the halogen fluid? Because that can make your alternator overcharge the battery if the belt is too tight. I assume you tightened it using a tensioner gauge? Chances are if it's your alternator failing because the e.g.r. filter is clogged OR BYPASSED, than chances are it killed your battery too , but that's better than hollowing out your catalytic convertor and putting it back on just to pass a visual. When is the last time you checked the tire balance?
What is the airspeed velocity of an unladen swallow?
Wat?
Do you mean a European or an African swallow?o_O
Do you think it's the alternator or the battery?
Yes.
But why are you banging them coconuts together Patsy?
:33:
78C10BigTen
pennsylvannia
C10 BIG TEN
Srsly?
What a fun game.
Wat?
Yes.
:33:
Are you suggesting coconuts migrate?
78C10BigTen
pennsylvannia
C10 BIG TEN
On the real note, same thing happened to me, alternator **** on me
CSFJ
Sounds more like a turbo encabulator issue.
Mine did that many moons ago at a Subway.
Got a jump. Guy said you need a ground wire going from the frame to the body.
Added wire from frame to body. End of problem.
Favorite color is orange.
Scandia
