Truck only starts sometimes (Distributor?)
Restoredrust
Hawaii
Brandon
350 v8
Hey, so I bought this 86 Scottsdale and for the first couple weeks it ran perfectly, no problems starting, it was great, but recently I haven't been able to get her to start, now there were problems with the alternator and battery but I've fixed those, my fuel line started leaking so I fixed that too, so ive got power, the truck charges and I know the fuel is going into the carb so now I'm looking at the distributor, so I managed to do a little research and found that the ESC doesn't even exist, the wire with the fused link that goes to the computer was not plugged in and the spark plugs were just horrible, so I replaced the spark plugs and plugged in the fused wire which goes to the computer and the truck started up on a dime... at least it did for about 2 hours, I went to start it up again just to see if it would and well, here we are, im not sure what to do at this point, I dont know much about distributors and the previous owner of this truck is not making it any easier for me :893Chainsaw-Smilie-
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Does it have spark while cranking when it doesn’t start?
Rusty Nail
Rusty
350sbc
I could only see the power source slow burning whatever is at the other end.
He plugged in something that had been unplugged - on purpose - then walked away.
I think he's lucky the truck didn't burn down.
If you don't know what you're doin, I would be VERY HESITANT about applying power to things unknown.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Me personally would be ripping that crap off and put in a non ECM controlled HEI distributor. On this old stuff I like to keep it simple. That ESC was crap in 86 and it’s crap now lol
Restoredrust
Hawaii
Brandon
350 v8
In response to the fused wire, it isn't a wire connected to any fuses, Idk its probably not what its called thats just what I read it was called. It was one of the wires that goes into the distributor, I'll take a picture when i can
Restoredrust
Hawaii
Brandon
350 v8
Sounds like good advice, also I dont know if it sparks when it isnt starting, is there a way to check with a multi meter / test light?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Just pull a plug and put the wire back on and rest it on the engine so the plug is touching metal. Have some one crank it over and you watch for spark.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Was this originally a CA truck with an E4ME carb, an ECM, and all that, or is it a 49 state truck with just the ESC module and a regular carb?
Restoredrust
Hawaii
Brandon
350 v8
It's just a 49 state truck with the ESC module and regular cab
Chype1
