Truck only starts in Neutral
Manswame
Alaska
Sarah
So the other day I went to start my truck and nothing. Shifted it to reverse and back to park...starts right up. I had to do that for a half dozen times or so before it wo ull ldnt start even doing that. So I shifted it to neutral and itll start right up. I know theres a position sensor on the tranny and I'm assuming this is going bad but can anyone verify this or give me a troubleshooting tutorial?
Appreciate ya.
Preston
Mechanicsville VA
Preston
There is a neutral safety switch I believe at the base of your steering column in the floor check to see if the wires are loose wiggle things around to see if it makes any differance
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
The switch is located at the base of the steering column the purple wires are for the starter and the green are the backup lights
WFO
Texas Panhandle
If it starts in neutral, the switch should be good.
Maybe the linkage has slop in it, and even though it's going into Park, it's not activating the switch.
Manswame
Alaska
Sarah
Gearing up for a hunt this weekend so I'll get back to tinkering next week. Thanks for the input.
75gmck25
Northern Virginia
Bruce
Before replacing my old cab bushings, the cab had settled enough to throw the linkage out of alignment. It would start in Park, but not Neutral. After replacing the cab bushings everything came into alignment and it starts in both shifter positions. My point is that the Neutral safety operation is affected by both cab and transmission vertical alignment, although you should be able to adjust it and get it to work in both positions.
Bruce
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Check the rubber and plastic bushings on the shifter linkage. If there is any slop there you will have a rough time getting the switch adjusted correctly.
  • Like
Reactions: WFO
73c20jim
Tombstone, AZ
I had same problem. New NSS and careful adjustment solved the problem.
millernf
