Truck 10 bolt or Truck 12 bolt
Truck 12 bolt or Truck 10 bolt
  • 10 bolt
    Votes: 1 8.3%
  • 12 bolt
    Votes: 4 33.3%
  • You're stupid, stop wasting money on this and get a real axle, Vince.
    Votes: 7 58.3%
  • Total voters
    12
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
3 options, 14 bolt FF, 9" or Dana 60. The 10 or 12 bolt weren't meant for 800 HP.
If I could find an older dodge or Ford Dana 60 car rear end in 5 lug, I'd be down for that also. But sheeeeiiittttt
Good luck on that one lol
dvdswan
Port Orchard, WA
Dave
Technicalities. These were mere suggestions to assist with your problems on hand. LOL
Craig 85
Nashville, TN
454/TH-400/NP205
I'll throw another thought out there. The early 90's 1/2 ton 454SS pickups had a SF 14 bolt 5 lug set up.
Craig 85
Nashville, TN
454/TH-400/NP205
And those 454 SS trucks were only putting out less than 250 horsepower.
I was just throwing it out there as a possible cheap option. I'm well aware of the low HP ratings. My GM rebuilt 454 in my K30 is a 1990 version with a whopping 230 HP...:banghead:
WFO
Texas Panhandle
They do have 385 pounds of torque though.
I just meant that the 10, 12 (truck) or 14 bolt aren't really built for high power holeshots, at least not for long.
Vbb199
Salisbury NC
Vince
Kinda reminds me of the time I was in my buddies Tahoe. We're riding down the road and start hearing this roaring and say "is that the wheel bearing, or the tire?"
*stomps on gas*
"We'll find out at 80"
MikeB
North Texas
I don't know much about 9-inch Fords, but I do know the early models had 28-spline axles. If you get one, make sure it has 31-spline axles, unless you plan to replace the axles and side gears. Also, if you could find one with a nodular iron case, that would be cool. Look for the "N" cast into the case.
Catbox
Peter
C20 Silverado Camper Special
9” eats too much hp up. Strength doesn’t justify its parasitic until 1k hp imo. Especially in a truck application where traction is questionable
This is a known factor as well.
This is from a source on the internet, Chevy High Performance.
"Another difference between the two rearends is that the 9-inch locates its pinion gear lower on the ring gear to improve tooth contact. This strengthens the rearend assembly but at the cost of approximately 2 to 3 percent loss of power to drive the gears compared to a 12-bolt. Of course, the sizes of the gears, cases, and bearings are relevant to strength, so you have to give the strength comparison to the 9-inch with its 0.125-inch larger ring-gear diameter and internal pinion support."
The numbers published in National Dragster, in a tech article by Evan Smith show:
Dana 60 - 5%
GM 12-bolt - 7%
Ford 9" - 10%
So 3% power loss difference between his 12 bolt and a 9". That would mean that at 600hp he would be losing about 18hp more from a 9" than he is from the 12 bolt. That may or may not be offset by differences in weight or strength... I'm not sure
Vbb199
Salisbury NC
Vince
Dana 60 - 5%
GM 12-bolt - 7%
Ford 9" - 10%
I did some more reading in my own spare time, plus all of your wonderful gentlemens input, and decided I'm going to build the truck 12.
Especially after learning about @CoggedBelt75 running a 12 bolt behind a truck with a trans brake and blown 383 stroker.
He's a modest man, and won't reveal his HP numbers, but I suspect when he's spraying it with laughing gas + his supercharger we're close to or on par in HP and torque.
I don't think I have much to worry about as long as I build the 12 bolt well.
CoggedBelt75
Altus, Oklahoma
Joe
Nope. No n2o. Would rather run a Super Chiller but not worth the expense. And I really don’t know any numbers. If I did I wouldn’t give them out anyways. It kills the local guys not knowing what it puts out or track times. I prefer it that way:p. If I wanted to go fast, I woulda went the procharger route.
Catbox
Peter
The roots superchargers just look so much better.
Vbb199
Salisbury NC
Vince
I've already seen the secret sauce from my personal experience....
Its not the amount of HP.
It's the efficiency of the PowerPlant that's inside a <4000 # truck
sammygunns
