Troubleshooting Your TBI Fuel Injection System
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Trouble Code
SYSTEM
Indicating
12 Diagnostic Checking for operation of CEL bulb
13 Oxygen Sensor Circuit No signal to computer
14 Coolant Sensor Circuit Excessive HIGH temperature indicated
15 Coolant Sensor Circuit Excessive Low temperature indicated
16 VSS - Vehicle Speed Sensor Signal Loss
21 TPS - Throttle Position Switch High Signal Voltage
22 TPS Low Signal Voltage
24 VSS Set when in motion only - disregard if set in park
32 EGR EGR system failure
33 MAP - manifold absolute pressure sensor MAP sensor voltage high
34 MAP MAP sensor voltage low
35 IAC - Idle Air Control Motor Idle speed above/below desired idle speed
36 Idle Speed Control Actuator Open or Short Circuit
42 Ignition Control open/short/component failure
43 ESC - electronic spark control ESC module not receiving knock sensor signal
44 Lean Exhaust Low oxygen sensor voltage
45 Rich Exhaust High oxygen sensor voltage
51 PROM (Memcal) Faulty computer chip
53 System voltage high Carging System is over 17.1 volts
54 Fuel pump relay Low voltage / short
55 ECM Computer (ECM) failure
The first diagnostic that I do in a non-start situation is squirt a shot of ether (starting fluid) down the throttle body.
If it momentarily fires up - assume a fuel delivery problem.
If it just cranks over and doesn't even attempt to fire - assume an ignition issue.
Here are the non-start diagnostic charts for your vehicle:
Thanks for the additional info Chengy/Jerry! :handshake:
chengny
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Fantastic info. Definately gonna save this for reference...Thanks!
chengny
Dead link. :(
Is the check engine light required to get the blankety-blank thing to trigger the injectors? If so, then I'll need to get that hooked up on my truck.
Download the complete manual.
1987 GMC Light Duty Truck Fuel & Emissions Including Driveability Manual
11 MB, 262 pages
Re-upped. Try it now:
http://depositfiles.com/files/xhf2z5s3d
JACK34
Banned
OTR TRUCKER
JACK
I have a 1994 and have replaced everything but the Engine. TBI trucks are junk. Good luck.
tadslc
Birmingham, AL
Tad
I'm not sure why this is still a sticky.
Pictures aren't showing up and links are dead.
spartantx117
