- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
Yep....it sounds like I got my answer, though. Basically don't worry about it until it happens all the time and then it's time for a rebuild.
Pretty much so. But, this doesn't mean it's on it's way out. A sticky valve or solenoid, making it have a harsh shift is something altogether different than the constant hard shift from a broken hard part. It can give the same symptom but because it's not constant, it's only an intermittent problem. IF it was a broken hard part, then it would be more constant and then you drive it until it just breaks loose and one and done.
