bigcountry78
- Apr 16, 2013
- Hickory, North Carolina
- James
- K10 Custom Deluxe
I spent most of the day running a new wiring harness on my father in law’s trailer so I can haul a tractor this spring. During the work, I found out that it has brakes. So I wired in a controller that I had courtesy of @Vbb199 and put a 7 pin connector on the truck and trailer. Now, as far as I can tell, everything on the truck side is right. I have running lights, turn signals, and brake lights. Brakes seem to work also. But when I turn the four way flashers on, it activates the brakes every time the lights flash. I can stand next to the trailer and hear them activating. It ONLY does this with the four ways on, not left or right turn signal only. Also, when I activate the controller manually, I noticed the brake lights on the trailer lighting up as well. Any ideas? This is my first go around with trailer brakes, and I’m stumped.
