Torque converter lock up kit for 1986 GMC Jimmy
sqaurebodyrestore
Armada Michigan
Dale
Jimmy
I am installing a torque converter lock up kit on my GMC Jimmy. The kit comes with a switch that mounts up by brake pedal. However, the truck already has two switched up there by pedal. I believe on is for cruise and other for brake/lights. Any know of a way to fabricate so I can install this switch?
Not sure what to do. I may have to eliminate the cruise control so that I can mount the switch in its position.
Any ideas or suggestions?
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I’m guessing the switch that’s included with the lock up kit will be the same as one of the switches under the dash. One switch will be for the brake lights (orange and white wires), the other one will be go the cruise and converter clutch.
mattyb
