Tire size?
Illinois
Daniel
C20 GMC High Sierra 2500
454 7.4L
What is the biggest size tires I can fit under my truck without a lift? I have a 1984 GMC high Sierra c20
waterpirate
delaware
v10
5.7 tbi
Hi and welcome. We have multiple threads covering this. Short answer is prolly 31x10.50x15
45tt
Florida
MJ
GMC Sierra Grande K15
32x11.50x15. I had a K10 that needed tires but I couldn’t afford a lift, so that’s the biggest I could go at stock height without rubbing.
edit - I just reread your post. If you have a two wheel drive, the 32’s will probably rub in the front. 31’s will probably be the better option. If it’s a 4x4 then 32’s will fit.
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Illinois
Daniel
454 7.4L
So you think that the IFS on your he 2wd has slightly less clearance than the 4x4 would?
BKING33
York Springs, PA
K30, Suburban
6.2, 6.2 turbo
I have 265/75R16 on my 3/4 ton 2wd Burb.
Illinois
Daniel
454 7.4L
No lift? And are they big enough for you or do you feel like you need bigger?
BKING33
York Springs, PA
K30, Suburban
6.2, 6.2 turbo
No lift. Just have 2 extra leafs in rear spring pack for towing.
45tt
Florida
MJ
I was just thinking that 2wd’s usually have a rake in the front that you need to compensate for, and a taller wider tire may not fit like it would on 4wd models.
Illinois
Daniel
454 7.4L
What is a rake?
Illinois
Daniel
454 7.4L
Good to know, thank you
45tt
Florida
MJ
What is a rake?
usually on factory 2wd’s the front end is slightly lower than the rear of the truck, this is called a rake. Some 2wd’s have a more noticeable rake than others.
Illinois
Daniel
454 7.4L
Ohhh, thank you for clearing that up
At stock height, I've found you can get away with bigger tires on a 2wd vs a 4x4. The front track is narrower and the suspension geometry keeps the tires off the fenders.
I've run various "33's" on my '78 C20 and nothing has contacted the fenders. I've run 285/75/16's on stock type narrow rims, 12.00x16.5's on 9.75" wide rims, 33x12.5's on 9.75" wide rims and it has all cleared the fenders fine. I'm currently running the 285's up front and 35x12.5's on the rear and I'm considering running 35's up front just to see how well it may or may not work. I'd have to trim the fenders though.
dynoh350
