"The Big 3 Upgrade"
heffalump
Lafayette ga.
jeremy
2500 suburban
Great thread HR.. I did this to a Honda civic I had years ago... No big stereo or anything just did it for the hell of it mostly, but I was amazed at the difference it made.. Headlights were brighter, started and ran better too... Plan on doin this to the burn soon..
slowgo
wa
Blake
V3500 3+3
454, nv4500, 205, 4.56 rp
Sorry to wake up old thread but has anyone considered keeping the fusible link from battery to alt? I just did this to my truck and was curious
350runner
tx
Ceasar
I just used a 200 amp breaker found in most audio setups. Something about reducing the wire size while adding a bigger one for more current flow didn't sit right with me.
We don't mind old threads being woke up, revisited and used. That's what they're here for. Especially the Tech threads. Add all the ideas, opinions and questions you want. :waytogo: That's how we make the threads even better, and more modern as technology and products come available.
350runner
tx
Ceasar
novassracer12
Arnold, CA
what are some of the alternator options available. I thought about using one from a 2003 Silverado I had. just unsure of the wiring or brackets. all the other upgrades mentioned I have done along with a second battery. I used 0 gauge wire that I had left over from a electric forklift job at the shop. maybe over kill but its stout for sure. I also ran a pos and neg set up with a quick connect terminal used on electric forklifts to my front bumoer for jumper cables. I own a service repair shop and when doing road calls it comes in handy.
350runner
tx
Ceasar
the CS 130 and CS144 are what most use. If you don't mind figuring out the brackets and the wiring I'd be interested in your results
neginfluence04
Oklahoma
Melvin
K10 Sub
I plan to do this when I install all my exterior led lighting.
350runner
tx
Ceasar
Definitely wouldn't hurt :)
Catbox
Peter
C20 Silverado Camper Special
I have done this to all of my cars for some time now.
I go to the local welding supply store for the cable and connectors.
Although some times I just build the connectors from copper piping.
I had many photos of what I had done, but they are all lost on photobucket...
Catbox
Peter
I have found one of the full write-ups on building your own battery cables that I have done in the past on a different forum.
I can either post them all here.
There are 37 photos with captions.
Or I can post them in a new thread.
@HotRodPC since this is your thread I will ask you what you would like me to do with them.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Your new LEDs will not need the extra balls, but all in all still a worthy improvement imo.
Okay somebody linked this to a recent thread, I only read page 1 and page 6. What is stated is good info,but incomplete. The body needs a good ground also.Most things in or on the cab/body are grounded to the cab or body,so the cab/body needs a good path to ground. On a truck the bed needs a ground also. I run battery neg. to alternator bracket, battery neg.to radiator support, and 6 gauge ground from block to frame. 99 percent of us should also have a ground strap from the firewall to the passenger side cylinder head.
Carb'ed Vortec 350
Having extra grounds in all the right places is never a bad thing. Unfortunately a lot of vehicles out there have some sort of grounding issue.
Not starting trouble,reiterating,for those that don't know. Grounding the body,no matter where you do it,is not an extra ground it is an extremely necessary ground
Misty Blue
