Th400 Kickdown, need help buying the right one...
Oregon78k10
Albany
Wes
350 V8
ok so Iv got a 74 k10 with a th400 in it... I know its an electric kick down and part of it mounts to the bottom of the gas peddle.. only issue is im finding alot of different things on ebay for it.... so can someone post a link to the correct one pleassssssse:)
these are what im finding
http://www.ebay.com/itm/New-Lokar-H...Parts_Accessories&hash=item3ccf801eb1&vxp=mtr
I was told by Jegs that this one is all i needed but they werent sure...
http://www.ebay.com/itm/Lokar-KD-24...Parts_Accessories&hash=item5d3445de32&vxp=mtr
Nope it's neither one of those.
The one that mounts on the gas pedal bracket is wicked simple.
Looks like this:
$28 at American Classic:
Part Number: EL870NOS-1975
Part Description: Throttle control switch, for TH400 transmission, GM NOS, also called kickdown switch, works for 1975 Chevy or GMC trucks
Price: $28.00
http://www.americanclassic.com/Google_Base_HTML_Pages/EL870NOS-1975.htm
Oregon78k10
Albany
Wes
350 V8
So all I need is that switch?
What's wrong now? Why are you ASSUMING it's the switch? Do you know which switch it is? I'd hate to see spend the cash and that's not the issue. How you checked the wire to make sure it's connected? Are you sure you've got power to the kickdown switch at the pedal? This could just as easily be the wire slipped off in the trans pan, or the solenoid inside the pan has gone bad too.
So tell all. Was it working fine, then all of a sudden you notice it don't work? Recent trans swap? Any other electrical issue recently?
beetlejuice01
