- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
So I just swapped a short tail th400 into my C10, the trans had a fixed yoke. I was replacing a th350 long tail. I wanted to keep the stock shaft and swap on a larger slip yoke and remove the fixed yoke that came on the th400. I remember reading somewhere that this swap was as simple as unbolting the yoke and sliding in the new slip yoke. So that's what I did.
Only problem is that the yoke doesn't go very far into the trans before it bottoms out. With the shaft installed (which was very tricky because the lack of travel) I only have about 1/2 inch of travel before it bottoms out. I "think" it will be OK like this, but time will tell.
Has anyone else actually done this swap? Were there any short tail th400's that came factory with a slip yoke? If so, how long was the yoke? The yoke I'm using is much longer than the smaller th350 yoke.
