Th400 being in 3rd by 25mph
Hutch998
Wisconsin
Jake
I've never worked on an automatic before and really need some advice. My truck is an 86 k20, with a mild built 355. I'm trying to make it more road worthy, and I know it shifts into 3rd at about 25 mph. How do I fix this? Any help would be great!
74 Shortbed
If you want later shifts you can adjust the modulator valve, remove the vacuum hose and use a small screw driver and give it a 1/2 to 1 turn at a time clockwise and try it, if you can't get what you want out of the modulator then you'll have to change springs in the governor..
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
Yep, mine was doing the same thing. 1 1/2 turns in and now it shifts just right. Most people will install a new modulator and never adjust it.
87scotty
Central il
Andrew
V20
5.7 for now
Ohh thats good to know thank you
DoubleDingo
Right where I am
Bagoomba
Carb'ed Vortec 350
Yep, mine did the same thing. Got a new one with the red stripe, and adjusted it until I got the shifting I wanted from the tranny.
garrettkeith
