Th350, th400, 700r4?
Simpleman87
Weatherford ,tx
Ivan
How can you tell what transmission you have what are the diff. In them the 350 can take the beating 400 is a beast and the 700 is the best for fule Eco. Right?
jt1200r
Huntingtown,MD
Jeff
r10
4.3/th400/3.08
look at the oil pans. the 350 and 400 are 3 speeds.the modulator is in different spots.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Yep, modulator is at the rear by the tailshaft on the TH350, near the front on the TH400, and the 700R4 doesn't have one at all.
johnmc
mass
john
k 10
305 tuneport injected
modulator is on pass. side on a 400 and rear on a 350.
A 700r4 built right is better than a 350 . it has a lower 1st gear and overdrive .
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
What are you planning to do w/the truck Simpleman? That might make the decision for you? If it's a mall crawler and you're keeping the 305 or other replacing it with a stock-ish 350, then I'd go with the 700 for the fuel savings and lower 1st. Here are diagrams to help determine what you have.
http://www.lmctruck.com/icatalog/csb/full.aspx?Page=8
I'll disagree that a 700r4 is better than a 350 even properly built. Even properly built, the Th350 is more durable. You are correct though about the lower first gear, but that also creates another disadvantage. There is a wide gap between 1st and 2nd on the 700r4 cuz of the lower first gear.
Bottom line, it all depends on the what you intend to use the vehicle for. I'd only go with a 700r4 if I was making a grocery gitter and daily commuter where mpg is important, and I'd only do that if I were running 3.73 gear or lower to take some of the strain off the 700r4, and still have the OD to compensate for it. So actaully, the decision needs to be based on, what's the vehicle main purpose, whether it be a weekend cruiser, street/strip truck, daily driver, or basic work truck for hauling the ATV's around or mowing lawns on the weekends, then what gear ratio does the truck have in the rear, and are you willing to change it to be a good match with the trans.
Camo
mobile
1500 extended cab 4x4
4.8 V8
Just look at the transmission pan to identify the trans,
Villano
